Working direct for the developer/owner or as a specialist sub-contractor, Interactive are able to add value to most schemes. By applying our in-depth understanding of the Building Regulations, we are able to provide a solution which best meets the needs of the project. This could be a simple code-compliant design following the guidance given in the Approved Document, a recognised alternative such as a British Standard or an Engineered Solution which we have designed for a specific application.
Residential projects can overlap and fall into other project groups such as education and healthcare but in the main fall into three categories;
Each of these categories has their own specific needs for smoke ventilation and the fundamental requirements of each are described within Approved Document B- 2006 edition (the current issue). Interactive have a range of packages which we use to produce effective and efficient systems.
Where the designer wishes to deviate from the guidance, i.e. extending travel distances or simply wishing to provide a space saving solution, Interactive are ready to help. We have developed a number of systems which come under the banner 'SmokEvac'. These are designed to meet the precise needs of the project. Using computational fluid dynamics (CFD) and advanced computer aided design software, we are able to accurately simulate conditions within escape routes as part of our design process.
